GregValiant 1,259
Cura marks invalid surfaces with a polka dot pattern. Your model has several areas with flipped normals.
When I try to repair the model the entire thing disappears.
So one reason you can't get rid of the support is because the "top" surfaces down low in the model are calling for support on their upper sides.
Both models are in need of serious repair.
Here is what I get when I tried to bring a support blocker in. I've never seen this before. The entire world turned inside out.
Spark908 0
Here is the attached 3mf file for a full view of the object I'm trying to slice. I've always had an issue of Cura incorrectly wanting to put support at the intersections of complex merged meshes for dual extrusion, and I'd love to try and figure this out.
DEBegleri.3mf
