ok this is strange, i changed the minimum travel to 100mm and nothing changed.
also set minimal extrusion before retracting to 5mm and nothing changed.
i even restarted cura and uncheck enable retraction before loading the models, and it still show the blue lines.
could it be that the blue lines dont mean "retraction" and just "travel"?
Dim3nsioneer 556
Does it change if you set the minimal distance after retraction to e.g. 2mm or 5mm?
