My regular PC is out of commission at the moment (since when did motherboards start requiring two 8 pin ATX connectors, and why can't Amazon get it to me next day when I order only 12 minutes after the cutoff time for next day delivery?).
Anyway, rant over. Turn off Mesh Fixes > Union Overlapping Volumes.
PizzaTijd 12
One way to do this would be to add a support blocker, adjust the size so it occupies the part you want to be solid, and then use the per-model settings (cutting mesh) to print that area at 100% infill, causing it to be printed solid.
Edited by PizzaTijdLink to post
