Indeed, as PizzaTijd already mentioned, no actual threads seem to be cut out.
If you use Inventor, you can use ThreadModeler to convert the thread drawings to actual threads.
PizzaTijd 12
There doesn't appear to be any physical threading in your part.
While I have no experience with inventor, other CAD programs tend to just create a hole and slap a texture on it to tell you "here there be threads" - which is exactly what happened on your part.
Either you still have to turn physical threading on somewhere, or you have to manually make a helical cutout with the right dimensions and pitch to create your desired thread.
Edited by PizzaTijdLink to post
