Thanks so much for your guidance. I will give it a go tomorrow.
Regards
Brian
Regards
Brian
The main reason I went this way was so that I could increase wall thickness on the sleeves without increasing wall thickness of the whole print.
If I redid the model as three separate pieces within the same model, would I then import the 3 models into Cura and then group them together.?
There's a (reasonably) easy way you can increase the wall thickness on the sleeves with the whole piece being a single model.
I'm attaching the one I just did but please do it yourself, it really helps the memory to practice doing it yourself.
Thanks again. Appreciated.
Slashee_the_Cow 271
I had a whole bunch of stuff that I wrote up before I dug a bit into your project file and saw that each printed part consists of three model files.
This is, to use the technical term, bad. Cura is clearly slicing them as separate objects:
They should all be combined into one model file (easy, plenty of software that does it, and it guarantees it's in the right place).
But I will do the
irresponsible thing and tell you how to do what you're trying to do. You're trying to avoid this, right, where objects aren't quite aligned (on the right)?Open the Object List at the bottom left. For each part of the same set:
(not a great screenshot because the object list isn't big enough to show them all - I just helped someone with that lol)
Then after you've made your changes, group them back together.
Also I can't help but notice that the centre cylinder especially isn't round:
By my count that's about 32 sides. You can even see it in the preview, instead of being round you can clearly see where it changes angle each time:
The effect isn't as bad on the inside though. Or maybe this could be part of your gear design or something. I don't know.
A couple of other things:
Speaking of which, go set Walls > Minimum Wall Line Width to 0.24mm, that can generally be done on your average printer.
Anyway, when the model isn't the exact size of what Cura can print, it determines how it rounds.
The brightly coloured lines are from the preview with the maximum resolution set to 0.1mm. You can see they follow a rounder path than the others, although it's only going to be so round anyway given your edges aren't exactly round themselves (you can see the individual faces):
