Pictures or a video wouldn't hurt either. As slashee said, prime/purge towers are meant to look sloppy. Whenever I use it it's usually completely covered in oozed blobs of breakaway - which then don't end up on my proper print.
Where it gets weird is that the blobs interfere with your print head enough to the point where it's pulling the plate with it. Prime towers are generally pretty thin in diameter and should just fall over if you apply any real sideways force on them - the amount of adhesion you would need to your build plate would be pretty impressive (ofc this is with my specific printer setup, which is an S5 with a heated glass build plate)
Edited by PizzaTijd
Slashee_the_Cow 272
It would really help if you could share your Cura project file (.3mf, in Cura get it ready to print then go to File > Save Project). At least knowing what printer you have would help 🙂
I'm not sure if you're using the term "purge tower" correctly 😕 A purge tower is what a multi-extruder printer prints in a corner usually to get the new extruder ready when before it starts printing with it. It's completely there for function and doesn't matter if it looks like crap.
I'd be very surprised if your nozzle was able to grab or push the model with such force as to move the print bed (unless the magnetic force from the bed is so weak it couldn't even hold a paperclip). Skipping a step or two on the motor when it hits a blob is something which might be possible if you don't have your belt tensioned correctly.
You might also want to check your setting for Travel > Retraction Extra Prime Amount: if it's retracted the filament, that makes it push a bit more than was retracted out to make sure there's enough pressure in the nozzle that it can start extruding as soon as soon as it's supposed to, but it can also result in overextrusion. I've never needed it, but it really depends on the printer (and you're more likely to need a little bit if you've got a Bowden extruder just because of how long it takes the filament to react to changes).
Also if Travel > Retract at Layer Change is on, it'll be doing that every layer, and if it's overextruding a bit that effect can sort of build up.
Without a project file or anything to go on it's really hard to try and make informed suggestions.
