I am using 5.7.0. I'll try 5.7.1 Thanks!
Cura 5.7.0 won't slice a model that fits on the Ender 3 Max Neo build plate/says its too big
- 2 weeks later...
I removed 5.7.0 and all its data files including the ones under AppDate then installed 5.7.1 It still won't accept the file at 100%. If I try to scale down from 100% to 99% it won't work. But if I scale it down to 95% then scale it up one percent at a time I can get it to 99% but not 100%.
GregValiant 1,488
Well that's pretty bizarre.
When you installed your printer in Cura which definition did you use? When I open that project file it uses a standard Ender 3 with a bigger bed.
Here is a project file with your model. The printer name is slightly different. If you get an option to allow Cura to install a new printer - do it. If you have done any customizing to your printer setup in Cura (StartUp Gcode, etc.) you don't want it to get over-written by this project file.
Okay, scratch that "can't remember why": it's "machine_nozzle_tip_outer_diameter" in the machine definition. Most files don't overwrite it so they just use the value from fdmprinter (the base definition almost all machines are based on) which is 1. If I override it in my machine definition to 0.0, then I can get my cube up to 219.9x219.9mm on my 220x220mm build plate:
GregValiant 1,488
I didn't have any trouble slicing it.
What version of Cura are you using? The Ender 3 definition file has changed over time and some of the early definitions had "disallowed areas" that were reserved for the bed hold-down clips. Changing the build plate size in Cura would not change the disallowed areas as they were hard coded in the definition file.
This is in 5.7.1.
