How could I use extruder 2 instead of extruder 1 for UM2/2+?
Posted
· How could I use extruder 2 instead of extruder 1 for UM2/2+?
Hiya! Your always-trying-to-be-friendly assistant mod Slashee here.
You'll probably get a better answer if you post this question in the UltiMaker 3D Printers board since your problem seems to have a lot to do with the hardware.
If you're having a hardware problem with your printer, you should try searching the extensive knowledge base or contact support at the UltiMaker support site.
Slashee_the_Cow 274
