Ok! Here is the project file!
When I load this model it doesn't properly join the two objects
- Solution
I think the problem is that the holders don't quite line up with the base, at least once they're rounded to the nearest layer height and line width, as they're separate objects in the STL.
If you turn on Mesh Fixes > Remove All Holes then that makes the holders merge with the main part of model:
If you set Experimental > Slicing Tolerance to Inclusive then that makes sure all models are at least as big as they are in STL so it treats them as separate objects but it rounds up so that the ring holders definitely fit in the holes:
and rounds up the layers so there's no missing layer (orthographic view):
Of the two, I would pick the Remove All Holes option. It'll give you a cleaner looking print.
- 1
That works wonderfully! Thank you so much!!
Slashee_the_Cow 312
Blender isn't the best program at making STL files (although it's far from the worst).
If you could share a Cura project (.3mf, get it ready then go to File > Save Project) that would help a lot. It slices fine for me so the problem could be somewhere in your settings (which are saved in the project file).
