Auto bed levelling failures are maddening, the front fan seems to be usual cause as the wires tend to shear off the solder and produce electrical interference. The usual switch off switch back on sometimes helps, reslicing and resending the print appears to occasionally help too particularly with a not reaching the bed case or compressing the springs till the stepper overloads. We have found that not using WiFi but rather the ethernet port has helped alot and incidently with digital factory problems and bizarrely black screen lock outs. Going back a firmware version is worth try also.
mrender 26
