1 hour ago, arvidx said:Due to file type I cannot upload it here without spoofing the file extension so here's a dropbox link
You can upload anything* if you put it in a zip file 🙂
*Within the file size limit
1 hour ago, arvidx said:If I slice a file for the Aquila Pro.... I get a .gx file which when opened in notepad.... is an encoded executable looking file, file follows...
After the first 14.5kb it's just plain text gcode:
Looking at the binary data my guess would be it's a thumbnail.
arvidx 0
ok... so get this...
If I slice a file for the aquila from Voxelmaker, it produces a .g file that looks pretty stardard fair for a .gcode file...
I will also try to do some fiddling with the opening gcode to see what triggers the proper motion to layer 2. I have several projects going on so I apologize if there's time between responses.
So far as I can tell, the Aries printer from them was a totally closed system with this program and the Aquila Pro shares parts with that printer.
https://www.dropbox.com/scl/fi/0klvzrecaijomejs0vnau/cube-20mm-voxelmaker-aquila-pro.gx?rlkey=bzlcn8s5z75nht0gwvio113lo&dl=0
