fbrc8-erin 296
You might try Aquasys for support; it tends to work with high temp materials like PC: https://marketplace.ultimaker.com/app/cura/materials/InfiniteMaterialSolutions/AquaSys120
On 5/31/2024 at 8:00 PM, fbrc8-erin said:You might try Aquasys for support; it tends to work with high temp materials like PC: https://marketplace.ultimaker.com/app/cura/materials/InfiniteMaterialSolutions/AquaSys120
Hi.
I'll have a look.
For the moment i found some PTEG which will be enough for the print that i have to do.
Thank you
Dustin 160
Please see this article: https://support.ultimaker.com/s/article/1667337600656
PC + PVA is not considered a safe combination
CRigio83 0
Wow. well i switching to full support with CP then.
Thank you
