Starting gcode
G90 ; absolute positioning
M82 ; set extruder to absolute mode
M190 {material_bed_temperature_layer_0} ; Heat & Wait
G92 E0.0 ; reset extruder origin
G28 ; home all axes
M104 S160: set hotend temp @ 160 but continue
G29 ; Probe bed
G1 X380 Y008 Z15 F6000; move to corner
M109 S{material_print_temperature_layer_0} ; Heat & Wait
G1 Z0.3; set z-position for wipeline
G1 Y100.0 E20.0 F1000.0 ; intro line
G92 E0.0; reset extruder origin
but this is what cura sends
;FLAVOR:Marlin
;TIME:5096
;Filament used: 11.413m
;Layer height: 0.28
;MINX:182.81
;MINY:183.25
;MINZ:0.28
;MAXX:217.186
;MAXY:216.75
;MAXZ:75.04
;TARGET_MACHINE.NAME:Formbot Raptor
;Generated with Cura_SteamEngine 5.7.2
M104 S205
M105
M109 S205
M82 ;absolute extrusion mode
M190 65 ; Heat & Wait
G28 ; home all axes
G29 ; Probe bed
M109 S205 ; Heat & Wait
G92 E0
G92 E0
G1 F2400 E-3
;LAYER_COUNT:268
it adds the extra
M104 S205
M105
M109 S205
Edited by Steverc1572
Slashee_the_Cow 382
If you're using Cura 5.7.2, apparently that has a bug that can cause this, even if your startup gcode should be fine. Try going back to 5.7 or 5.7.1 (you can have as many different versions of Cura as you want installed side by side).
Other than that, IIRC if there aren't lines that heat the hot end to {material_print_temperature_layer_0} and the bed temperature to {material_bed_temperature_layer_0} it will add them automatically to prevent the printer trying to cold extrude or anything bad like that.
If you could post the startup gcode for your printer that would help us diagnose any problems.
And for the love of all things beefy, please no screenshots of text editors. This forum crushes image quality so badly that text becomes unreadable. Click the code
button on the toolbar at the top of the edit box and copy + paste your code into that.
