Unfortunately i cant share the .3mf file as the model i use is sensitive. I tried to recreate the problem with another model but i couldnt. so it's probably a foult in the (smoothness of) the model.
I do think its still weird the slicing tolerance of the 'Surface mode' makes such a huge difference in smoothing out polygons.
Slashee_the_Cow 382
If you could share the Cura project file (.3mf, in Cura get it set up then go to File > Save Project) that would really help. It looks like the sort of thing that's almost impossible to diagnose based on a couple of screenshots.
If the file is too big to post to the forum, it's probably best if you upload it to a cloud storage service like Google Drive (or whatever you use, if you already use one) and post a link.
