Would it be an option for you to assign a static IP address on your DHCP server (router)? This does not require you to modify your printer, and it will let you manage your static IP addresses in a central place (your router/DHCP server).
Unfortunately, UltiMaker does not provide direct support via the Community.
Please contact UltiMaker Support directly for help with this issue.
Slashee_the_Cow 450
Friendly Assistant Mod Slashee note: I'm moving this to this "UltiMaker printers" board since this really isn't a Cura thing (and they'll be a lot more knowledgeable about this sort of thing).
