Raft Problems in 14.03 test 2
parabolic
Posted · Raft Problems in 14.03 test 2
Using a raft on a ring im printing and the first layer works fine - according to my raft settings, however, the second layer prints at a 45 degree angle to it instead of 90 degrees and that layer has no spacing at all - like a solid infill.
After that the item prints on top of it fine...
Is this a bug or a feature?
    I'm been working with someone on the raft code, the TEST versions contain half completed versions of this, causing problems.
    However, he is getting awesome results with the final code.
    A fix for this 45deg angle is already in place.
