I lowered the z axis move speed a little. It also might be because I had the setting with layers under x seconds on and it seemed to create a lot of layers of different lengths. It seems to be reduced but that doesn't seem to completely remove the artifact. I'd assume the lack of responses are because its not an obvious fix. I think it all boils down to cooling of PLA as it lays down. If I find anything else to help the situation I will post to help others with a similar issue
mikey 0
http://imgur.com/wePz6VF
Another example. The printer is finally creating great prints except for the z issues.
