Right... this is what I've been wondering. My "Load profile from Gcode" stays greyed out whatever I do. I seem not to be able to select it. I've also loaded the Gcode back to the build plate but still nothing.
Am I just thick?
J
Am I just thick?
J
Expert -> Switch to full settings Will give you access.
I was thick
IRobertI 502
Use the "Load profile from Gcode" option found under the File menu and select a Gcode file that you have created using the basic settings. This will load in all the settings used to create that file.
