Movement of extruder motor (even without filament) causes temp reading to artificially dip and overshoot
Dim3nsioneer 557
Indeed interesting. Sounds like cross talk or (partial) short cut somewhere. Maybe you can check / answer a few things:
- Do you use an original UM shield PCB or a legacy board?
- Are the wires of the motor nicely twisted?
- Do the motor wires run in parallel with the sensor wires?
- Does the effect exist for any motor, i.e. also for x, y and z axis?
