Hey Ina, thanks for your reply. I fixed my issue with the replacement of the white teflon part (for now). I hope that your modifications / re-assembly will help.
Regards
Martin
Regards
Martin
Hi Martin,
I am glad you shared the problem with the teflon piece. I have exactly the same issue. However, what really intrigues me is how this happened. Since the carving occurs at the exit end of the teflon tube (facing the PEEK isolator), I doubt it is actually caused by filament scratching ("carving") into the material. I have been using some oil inside the bowden tube priviously and was wondering if this might eat on the teflon. Or could it be from heat from the hot end isolator tube. Anyway I have ordered two spares for now. Might consider changing to 3rd party hot end as has been suggested here.
Kindest regards,
Stefan
Stefan
that's actually a pretty good hint. I was using a tiny bit of wd40 in the tube, but only once... could it be that the oil is actually eating the teflon? I don't think so... but hey...
I have another theory. It's maybe to much force pressing the teflon piece together and then slowly carving it away... next time I open my hot end I will check.
Martin
fablab 0
Hi guys,
I've been away from this thread far too long from what I can tell. Martin, I had also started to think I was the only one with this problem.
Unfortunately, out Ultimaker is yet to work properly even after we replaced the extruder with the latest E3D.... we're thinking of replacing the extruding mechanism but I'm not sure It's broken and at this point I don't know how I can tell if it is.
I'll give it another go, take it apart and put it back together again...
ina
