I experienced that in 14.03 not always support structures are created, regardless which setting of support is chosen.
Attached link to an example of a simple figurine created in Tinkercad where the "arms" are not touching the build-plate. No support structure is created which results in an unprintable part... Actually I don't know if this worked in a prev. version.
https://tinkercad.com/things/fbgqNdOuRd6-lauras-figurine
Daid 303
Support can "bleed" a bit into areas where it should not go. The code that generates the support material is broken in a lot of ways. Including this one. The XY support distance parameter effects this.
