Hello gr5,
it's a 0.5mm nozzle.
here's the code: https://gist.github.com/vindolin/11106150
Thank you
Thomas
Hello gr5,
Thank you
Thomas
It looks like the M3004 thing. I don't know what that does but it says something about the "bed height" and in one case it is set to 72 and in the other it is set to 0. I think it needs to be zero in both cases as it sounds like you said kisslicer workd better and that is what kisslicer set it to.
Thanks, that was the problem
I thought the printer firmware would be responsible for the z adjustment but it only corrects the z delta and I had to find the correct settings myself.
gr5 2,224
Can you post the first few dozen lines of gcode from both slicers please? Up until it starts extruding on the first layer.
What is your nozzle hole diameter?
