Hey, so I'm upgrading the bowden clamps, the one at the hot end failed, and I'm replacing both as preventative maintenance. My question. How does one go about REMOVING the clamp at the drive end? (short of cutting off some of the tube). Is there a method to this that I'm missing?
once you see how easy it is, it's time for same facepalm... I had the same thing months ago.
owen 19
Push and hold down the inner ring. Pull the tube out.
