250000 baudrate, so maybe someone can upload here fully working marlin firmware with X and Y axis inverted?
axises dont work for me.
extruder stucked in the corner, and i cant control it.
Wait - so marlin works - but your x and y axes dont' work? Using pronterface (or replicatorg) command the servos *off*. Then push the head to the middle. Then put the X axis in *relative* move mode and move 10mm to the right:
G1 X10
Does it move right or left? It should move right. You might also (or instead) have the limit switches backwards? Those are easy to swap - just swap the connectors.
ginge builder works quite well. You can use Cura "expert" menu to load the firmware. You probably already know this.
More gcodes are here:
great reference:
scroll way down to the gcodes on this page:
https://github.com/ErikZalm/Marlin/
Posting a video of your issue might help us also.
Thank you , now x and y axis work fine. But when i try to print smth, Z axis going down for home, as i know it should go up, i will put here my compilation , so maybe u can help me.
Thank you for help, i made it work. So i had to invert 2 axis X and Y in marlin builder i have to do 2 ticks on Y and Z axis. So now everything works fine! Thank you very much! I appreciate your help!
gr5 2,243
Probably baud rate. What baud rate did you choose in ginge builder? 250000? Make sure replicatorg knows the correct baud rate and com port.
Also I recommend using pronterface instead. It's free and works well with Marlin:
http://koti.kapsi.fi/~kliment/printrun/
