How to read Gcode
robogrobo
Posted · How to read Gcode
Having just come up with the same question of how to understand G and M Codes generated by Cura I am pleased to have found this old thread,
Owen's link above worked fine but Daid's link seems to be dead.
Can you give an update please Daid.
And by the way, I tried to copy quotes from above comments but failed. How do you get the box with bits of other peoples quotes inserted into your reply?
Thanks.
    Thanks.
    Click on the quote button underneath the message.
    Or copy paste the text in the quote section that you can add by clicking the little icon in the menu bar (between <> and the t icon)
