Posted · 3mm on UM2
Hey probably the filament gets stuck because the diameter is over 3mm.
You can remove the filament. Then remove the bowden tube from the feeder and try to stick the filament through the bowden tube by your hand. If it gets stuck you know its to big.
cheers
Jonas
