Daid, I know this might be a dumb question, but the thing I came to love most about Netfabb is the way it does infill (and since I started using Cura, that and raw speed are pretty much the only things I miss from Netfabb). I print a lot with transparent plastic and it really looks good on those, plus, it seems more sturdy than the default line infill in Skeinforge, at least in my experience. Now, I know this is a Skeinforge feature but since I presume you delved into Skeinforge quite a lot while programming Cura, I have some hope you could do something like that. Is it possible? And thanks for an awesome piece of software. :mrgreen:
Go and have a look selecting grid or hex as infill patterns in the export settings... at 25-28% they are quite sturdy yet print reasonable, 30% looks like a 60% infill (is it a bug or a feature?). it is a "works all the time infill", independent from any/most speed settings (unaffected by M220), none of the crumbly/flakey mess cura/slic3r can produce at speeds >90mm/s.
but yes, a simply multiplier for cura infill would be really helpful.
Daid 300
Thanks for the software awesome
I've indeed done my share of Skeinforge hacking already. However, the infill is the part that confuses the hell out of me, I have no idea how it works and why it works. So I stay away from it. So I cannot make this feature. The first time I notice the NetFabb infill I already thought, now that looks pretty! But I have no way to implement it in SF.
