It's most likely one of the 2 X limit switches. Are the cables getting tangled up in the belts maybe? When a limit switch triggers for a given axis the other axis keeps going.
You can unplug the X switch on the right side as you really don't need it. Marlin has "software endstops" which work quite well. If that's the problem switch then you are "done". If it's the left one you have to figure out whats going on. I would turn off power and hook up a multimeter to the far end of the limit switch cable (under the UM) and then push the head around and poke at the wires and such.
Thanks, I'll check this out. I do have an Ulticontroller though - wouldn't it say that a limit switched was hit if this was the case?
gr5 2,330
