The heater is a custom cartridge heater (19V 40W), 5.92mm diameter (6mm bore), 25mm insert. a 1/4in x 1in will fit if you drill the bore. (google "cartridge heater", there are plenty of sources, I got mine from http://daltonelectric.com/cartridge-heater/index.htm (19V 50W cool tip angled leads, about $40)
joergen 2
The z-axis is a 12mm diameter 3mm pitch acme rod (12 X 3 METRIC ISO TRAPEZOIDAL LEAD SCREW)
The TC is a custom thermocouple, I believe it's a k-type. The TC board is here: http://reprap.org/wiki/Ultimaker's_v1.5.4_PCB#Thermocouple_sensor_board
