How can I place objects on the platform with coordinates
clemens
Posted · How can I place objects on the platform with coordinates
Hi ultimaker,
I want to print some objects directly onto a sheet. To have a really good print result I want to print the objects one after another. But they need to be placed on the right place. Is there a way to place them with coordinates ?
Hope someone can help me with that.
Clemens
    Hmm. Not with the gui drag/drop feature.
    I would combine all the STL's into one big STL file and slice that with cura - that way at least all the parts will be the exact correct seperation. Then I would probably do one of two things - in machine settings I believe cura centers your object on the center of the platform so you can adjust your X and Y max distance to cause Cura to place the objects properly.
    Or you can hand edit the gcode file with an offset. For example if you want to move X to the right 1mm and Y toward the back 2mm, after home do:
    G0 X1.0 Y2.0
    G92 X0 Y0
    That sets the x=1 y=2 position on your bed to the new 0,0 position.
