Cura 14.06 not loading properly?
qmaker
Posted · Cura 14.06 not loading properly?
I have Cura 14.06 on one machine. It seems to work great. I have another machine that I tried to download and install it on. When I launch the app. I get a message saying.
Cura Error
options are to open console or Terminate.
If I open console the last recorded error says.[2265} Exited with exit code:255
I deleted the application and re downloaded, installed and same message.
Any suggestions.
Thanks
    My apologies. I am running OSX 10.6.8
    Maybe that answers my own question. Perhaps the OS is too old?
    Hmmm.. I just looked and I am using cura 14.03 on my other system which is also OSX 10.6.8
    Thanks Hummel, I still haven't figured it out. For now I am just using Cura on my old machine until I figure out what the issue is.
    Note, I am planning to drop MacOS 10.6 support in the future. Apple is making it quite impossible to support it properly.
    (The hoops I jump trough to get it to work are quite... interesting. The fact that it works at all on 10.6 is a bit of a miracle)
    Thanks for the information Daid, is this true of the newer mac operating systems as well?
    Any insight as to what my issue is currently, or should I just chalk it up to a miracle that it is working on my other machine?
    I need to update to a newer OS, so maybe this is a nudge to do so.
    I updated to Mavericks, re-downloaded Cura 14.06 and I am still getting the same problem. Any thoughts?
    Does an extra error or something show up if you run it like this:
    Open the package (right click, show package contents)
    Go to Contents/MacOS
    There run the "Cura" file. A black console window should popup now, maybe giving an extra error.
    (The default Error console of MacOS is useless for Cura for some reason)
    I had a related problem with one of the older versions of Cura (Mac OS X 10.9.2 here). There seems to be the possibility of a race condition related to the options window (or advanced settings). I am not sure how I solved it but I remember that I tried quite a few things. Removing the subfolder related to that version in ~/.cura was one of them.
    And on another related note - Cura 14.06 didn't want to start properly once (dock icon bouncing forever). I killed the process a few times (too lazy to reboot) and once I let it start for a few minutes (icon bouncing like a boss), it finally started. Never had the problem again though.
    Ok, this sounds really dumb, but how do you open the package.
    When I right click there are no show package contents options. I know I have seen it there in the past.
    I did notice that there is a newer 14.06.1 version. I downloaded it and tried again. But received the same error.
    You have to right-click on the Cura.app file itself, not the folder it is enclosed in.
    cura package
    Ok, sorry, I was out of town for awhile on business and vacation. I opened the console and...
    The terminal shows a line that says Failed to create directory: / Users/useser/.cura/14.06.1
    at the end there ios a line that says the time followed by Cura [364:507} Cura error logout
    If I open the console there is a huge list of processes towards the end I am seeing errors but I am not sure what I am looking for here. If I had to guess it looks like it has something to do with either a security error or directory error.
    Is this similar to the error you were having Nicolinux?
    No, this wasn't the case for me since I started Cura directly and not from the console.
    Hi guys, just thought I would check in and see if anybody had any ideas. I have an email into ultimaker support now, but I am anxiously waiting to print :arrow: :unsure:
    That question will end up with me eventually.
    I've had a few more reports like this, and finally found someone who managed to make a proper log that I needed.
    What is happening, Cura tries to make a directory for configuration files, this fails. After that, it tries to save the configuration file in that directory, this fails and crashes Cura.
    I'll have a few things to try and I'll build a test version tomorrow for the people with this issue.
    Thanks Daid,
    You are probably receiving my requests for support on both ends then. Thank you for looking into it. I look forward to finding a solution. If there is any way that I can help with feedback etc.. just let me know.
    I've placed a testing version at:
    http://software.ultimaker.com/Cura_closed_beta/
    This version has 2 changes compared to 14.07, it changes the location where the configuration is stored. From /Users/user/.cura/version/ to /Users/user/Library/Application Support/version/ as that is apparently the proper location for configuration data. And it catches the crash when saving configuration to it should at least start (but will be unable to save data then)
    Hi Daid, Thank you. I downloaded and tried to install and open. It opened and immediately came up with the message Cura Error with my options being open console or terminate. As I scrolled through the console text (not knowing what I am looking at or for) I saw many errors. Perhaps I could email you the console error text? If that would help.
    Thanks again for your work on this.
    The default error console from MacOS is useless (boils down to "Apple hates me"). You need to go trough the "open package contents" procedure (described it above in this topic) to get a useful error message.
    Hi Daid,
    I sent the log to Marrit Hoffmans at technical support. I assume you will get it that way. If you would like to get it to you another way. Just let me know.
    Thanks for everything.
    Q
