Thanks for the response.
Sorry in my post I meant dimensions 30 X 50 X 20 mm (W,L,H)
To my perception it did sound as if it is trying to move the bed down in the form of a momentary stepper motor buzz after finishing a layer.
I turned the machine off and lifted the bed passed the error point then let it free fall, it stopped at the error point but extremely little force was needed to allow it to continue. There is a bit of a click at the error point, but there are other similar clicks as it continues it's free fall downwards, it does not stop again for the rest of the fall.
For testing I made another model 20 X 20 X 20 and it seemed to go passed the point (Z direction) where three attempts of the model I am trying to print failed. This might at the very least remove possibility of end stop fault.
IRobertI 520
I would start by turning the power off and then moving the bed up and down and check if there's an area with strong friction around that height. With the power off you can either lift the bed up by grabbing it as close to the back of the machine as possible and pull, or you can simply twist the z-screw (it's greasy though so be aware of that. At least it SHOULD be greasy, another thing to check).
Did you notice if it sounded like it tried to move the bed down at all?
If everything is moving smoothly then maybe there's something wonky going on with the end stop that makes it think it can't lower the bed anymore? Dunno, just thinking out loud.
