The problem is that its a very intricate design (one of Nervoussystem) which requires plenty of support. I haven't had the best experience with Cura in that department. I will try however Thanks for the reply.
Filament wasn't ground at all however, it just had the regular "track marks" on it from being passed through the feeder. Which is why I figured it got retracted too much. Also there is flow without obstruction it seems, so I don't think it was that.
SandervG 1,502
Usually when there is an obstruction somewhere the filament just gets chewed, but not consistently retracted.
(the reason it grinds is because it can not go anywhere).
So I think maybe there was some mistake in the gcode and it kept retracting more then it was priming (pushing it forward.) Have you already tried Cura?
I am not very familiar with simplify3D so I am not sure about any settings which leave room for play or how well tuned in it is..
