Posted · Brim not activating in 14.06.1?
For some reason, Cura won't add a brim (or a skirt) to my part. Could I have done something to cause this?
Brim is selected on the General tab, and 10 lines define in expert settings. Skirt settings are also defined to print a skirt at least 150mm long.
    I switched to another part with same settings, and the skirt is added, but not the brim.
    Also, my part is only about 45mm dia and placed in the center of my UM1 platform.
    OK, well, I got my brim back. I think the bottom surface (edge) is too narrow for Cura to make a slice for my .8mm nozzle. I set Cura to cut off .1mm, and the brim is back.
    Good enough w/o the skirt. I can use the brim to tune the height.
