Hey 3dguy.
Yeah when you pick the self build heated bed option for the UM1, the firmware that Cura will flash is for a different bed temp sensor. I've run into this problem and the only way to recover is to remove the Arduino and flash directly from the Arduino IDE.
I reported this problem with 14.06.
Previous versions of Cura (either 14.01 or 14.03, not sure which) gave you a message that the firmware for the custom bed needs to be supplied by you and refuses to upgrade the firmware that came with Cura.
I think that was a better solution than temporarily bricking the printer.
But it's up to UM/Daid to address.
http://umforum.ultimaker.com/index.php?/topic/6016-possible-problem-with-cura-beta-um1-heated-bed/
Daid 303
Cura ships with a firmware for a different heated bed by default. We're getting closer to releasing our heated-bed upgrade, so the firmware for heated-beds in Cura is prepared for that.
You should skip the firmware update in Cura if you have a home-build heated bed.
