I am the old 'blank screen' reporter...
I don't know how I solved, I tried everything and Daid told me everything he could to help but nothing.
I solved when I disinstalled some software from my system during a normal clean routine of my pc. from then on everything went right.
Anyway you have to check your video driver and keep it updated. I read that ATI cards give some problems with opengl and a new driver can help. at the same time any modification I made on videocards parameters didn't work.
good luck, cura is a fantastic software and can make your 3d printing life cozy and warm...
Daid 300
I've had 1 report of the same problem, also under 64bit Win7. (But there are enough Win7 machines that work fine) Not sure how that was solved, but in the end it was.
Check if you have DirectX and your latest video card drivers installed, that might help.
