coloring PLA filament by passing through body of Sharpie?
jbeale
Posted · coloring PLA filament by passing through body of Sharpie?
I thought this article was very interesting, and the results look convincing:
http://3dprint.com/3340/ulimate-filament-colorer/
Is this possible with UM2? It uses 3mm instead of 1.75mm filament (need larger diameter marker?) but it also has a bowden tube; would that make a difference?
Apparently it works better on "natural" color filament, than "white" for some reason.
    http://www.thingiverse.com/thing:77424
    http://www.thingiverse.com/thing:11742/
    http://www.thingiverse.com/thing:11236
    Now I don't have an UM2 but in any case I guess you would have to either color your filament before printing, even with a fixture to help it, but still doing by hand, OR while printing, by installing the fixture right before the feeder, making sure the friction due to the pen is minimal.
    I don't think you need to color it perfectly for good results. I used to make just black dots at regular step on a white filament to easily monitor its progress in the bowden tube, and just this was already affecting the rendering of my print.
    The issue will be the dilution of the ink due to the larger volume of the filament. 2.85 filament has a area of 6.38 vs 2.41 for 1.75. 2.85 has a circumference of 8.95 vs a circumference of 5.5 for 1.75 filament.
    So 2.85 has 2.65 times the volume of 1.75 filament but only 1.63 times the area to coat with the ink. So I think this means that the ink to filament ratio for 2.85 filament will be 62% of the ratio for 1.75 filament.
    I did this math without coffee so to might be off but the general point is that there will be less ink per given volume of filament for the 2.85 size.
