Cura issue for my setup (Or am I doing something wrong)
Posted
· Cura issue for my setup (Or am I doing something wrong)
Yes, you can!
In all versions, the M109 is not added if you set the temperature to 0 in Cura.
In RC3 you can add "tags" in the start/end code. If the {print_temperature} tag is found in the start code, then Cura won't add the M109 because it assumes you set the temperature in the start code yourself. The {print_temperature} tag is replaced with the configured temperature in Cura.
(If you do not want the M92, then you can set the steps-per-e to 0 in the preferences, this will remove that line)
Daid 306
Yes, you can!
