Thanks for the suggestions. Looks like one of the wires was touching the rotating shaft. I don't see any wear on the wire jacket, although it's hard to tell in such a tight space. I guess I'll have to see what iMakr has to say about it. If they want to send a replacement for the led module I can probably do the install. I need to learn to solder but I would rather learn on something less expensive
illuminarti 18
Start by looking at the wires up in the top right corner, and see if they're rubbing on the pulleys. Poke them a bit and see if there's a loose connection up there. Most likely the issue is just a bad connection between the second and third strips.
If there is, it may be as simple as gluing down the LED strips and or wires to keep them out of the way, and making good contact.
Beyond that you may need to resolder a new connection between the two strips, or simply replace the entire set of 3 LED strips with a new one. It's not really hard to do, but it is a little bit tight and fiddly to work around the pulleys etc. Best approach is to place the printer front down, and work through the top of the printer.
