192.168.1.5 ?
Blizz
Posted · 192.168.1.5 ?
Any reason Cura tries to connect to that IP when starting up? I realise it might be local to my LAN, but I have no clue why it would try to connect to a local IP, let alone one that is not in use..
    I wasn't insinuating that Daid :) I (kinda) trust you :-P
    Just didn't feel like browsing through the code as I don't really know where to start.
    But I could've done a github search in the repository :)
    I saw the topic title and was like, woa, that is the IP that I use to get into the Doodle3D box! So what happends when it detects the box? I'm not at home atm to test it.
    It's the NSA!
    When Cura detects the box, it enables the print button if a model is loaded as if you plugged the UM1 in...
        • 24 replies
