Regardless of why this was done , it should not happen.
I don't agree. UM / Daid has to set priorities. I prefer that known issues for common use cases get higher priority as a lot of people are affected by.
I agree with him. This should not happen. However, does not mean I instantly will fix it. Especially as this odd behavior of invisible settings affecting the print is fixed in the PinkUnicorn re-write. (Not that that version already support dual-extrusion. But invisible settings is part of the architecture, and invisible settings fall back to defaults)
Dim3nsioneer 556
Why do you switch back from dual head to single head? You don't have to in order to print a single extruder print. :???:
Sounds like a very rare use case to me.
