cura slicing issue with hole
hopmanhenk
Posted · cura slicing issue with hole
guys,
I have a cura challenge..
I've designed a smal part with an cylindrical hole in the base
683d52cf-5162-4939-b6f1-5c54292fb27b_zps
when I orient it in cura so that the hole is vertical the hole is filled (layer view also shows the hole not being there.
40b48e7c-06bc-44a6-8408-e9d6287ea950_zps73b89fb9-4155-4fe9-8fd9-f949f36ec577_zps
what am I doing wrong?
    The X-Ray view is showing red areas. This means there's something wrong with the model. You can try different combinations of the "Fix horrible" check boxes in the Expert settings and see if a combination there makes cura slice it the way you expect. Or you could try repairing it with netfabb's cloud service for example: https://netfabb.azurewebsites.net/
    A bit more info on the problem can be found here:
    http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide#randomfill
    Is that sketch-up? Then most likely, duplicate faces and internal faces. Sketch-up is quite bad for solid modeling actually. It has a tendency to generate bad models, as it's mode made for visual modeling.
    I'm not sure what you are exactly designing, but I usually recommend DesignSpark Mechanical (or it's bigger brother, Spaceclaim) for part modeling.
        • 4 replies
