Question about the slicing in Cura
Titus
Posted · Question about the slicing in Cura
Dear Community,
Curious as always, I had a question about something I see happening in Cura from time to time.
For example, when slicing this calibration pyramid, I noticed that when it's closing the bottom surface, it leaves 'holes'(X% infill) where the legs of the pyramid will come as can be seen here:
http://www.thingiverse.com/thing:8757
Hollow pyramid
It makes sense since if it were a bigger part, it would also just continue the mesh when going up, but especially for smaller parts, I believe the breaking point is quite often located here as it is a structural weakness. Would it be possible close these squares also, so that the legs are attached more firmly? This would require a general closing of the mess at some layers.
EDIT: Actually, there are 2 layers(0.2mm) completely closed before the holes start. But why not the entire top thickness?
/offtopic:
when printing this pyramid, putting the travel time at 60mm/s it estimated 26 minutes, at 200mm/s travel it was estimated at 28 minutes :O What could be happening there?
    What is your top/bottom thickness? You can also make your shell thickness bigger (nozzle size * number of layers you want).
    About your offtopic, its a good question. Do you use cool head lift? If so it could be triggered more often when going at 200mm/s and so waste more time. (Just a theory)
    Nozzle is .4, shell is .8(2 times nozzle)
    I try to keep the top/bot thickness roughly 5 times the layer height, .2 and thus 1mm in this case.
    /Offtopic: no, no cool head lift setting(yet)
        • 27 replies
