You can adjust the infill overlap in the expert settings, but you will always have some gaps.
that is not true... I print with 0 gaps, I have complete solid infill (15% overlap
Oh, yes, it also depends on the model. And you need to have proper belt tension.
Problem solved! I used a nozzle diameter of 0.254 mm, and filament diameter of 2.7 mm (actual is 2.82), and printing speed of 50 mm/sec, an infill overlap of 25%, a layer thickness of 0.12 mm (with skins enabled), and a print temperature of 215 for the gray PLA that came with the Ultimaker machine. This gave a very nice 100% infill without voids.
Daid 303
