Yes, it was one of the first things I did including changing some of the other settings that others Makerfarm users had done to get Cura up and running for them.
I thought about just increasing the bed size in Cura larger than my actual bed and trying to figure out/ eyeball the areas where my bed actually ends, but I decided not to due to the risk of smashing my x carriage. I also don't think it would get me more X Axis Minimum space.
You got me thinking though, I just noticed from my last print that there is same kind of issue in Pronterface once I imported the Cura Gcode. The last thing I printed showed that it was right on the edge of the bed in Pronterface, but it was off by 20mm.
I am starting to think it may not be the Cura software is is possible my firmware or Pronterface.
IRobertI 502
Have you gone into Machine -> Machine settings and then adjusted all the measurements to match your printer?
