Gcode question
zoev89
Posted · Gcode question
I am using a UM original with a heated bed. It takes some time to heat-up the bed so what I usually do is manually heat the bed with control->temperature->bed to avoid having my nozzle heated up all the time while the bed is warming up. Then I start a print. Being a lazy guy I would like to do this in the startup code. So I enabled the
M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
M109 S{print_temperature} ;Uncomment to add your own temperature line
lines in the start code. According to the documentation M190 S code waits for the bed temperature to reach the target temp. But what I see that it did not wait it also started heating up the nozzle while the bed is heating up and is not ready. I added a M0 command and that did seem to fix it like this
M0 ;Pause
Actually I expected that the M0 would ask for a conformation from the user but it did not in this case. It does ask for conformation in the 3 point bedleveling procedure that is found on this forum.
So currently with the M0 command I have been able to get the required startup sequence of my machine but actually I don't understand why the M190 command did not wait, and it does wait when I add the M0 command. And why the M0 asks for a conformation or not depended on the code following....
    Which version that is a good question but how to get that info...
    I took it from
    http://marlinbuilder.robotfuzz.com/
    In may 2014
    I can't get info or the version from the controller. The build_summary.txt at that time does not show a version number. There is the hex file but that does no help me much I guess.
    I feel so stupid that I don't know hot to get the version number....
    I saved the diff files for future reference.
    When I look at the generated gcode I see that the values are correctly taken over like
    M190 S115
    M0 ;Pause
    M109 S250
    I am still looking into the version. Try to connect the machine to the PC again but I am running ubuntu so there are some libusb acces rights to fix before it works I guess. I programmed it at that time on windows xp.....
    115°C for the heated bed is not low. I don't know where Marlin has the safety maximum. And I don't know what Marlin does if an external command exceeds this level. It might be worth checking if this causes your issue.
    True 115 is not low that is why it is taking about 15 minutes. I need to compensate for the 4 mm glas plate and I am printing ABS. Marlin has no issues with this temp I already did 125 for a experiment some time ago.
    HA I figured it out. There must have been a error in coping the data to the SD card.... When I have
    M190 S115
    M109 S250
    it correctly waits until the headedbed warms up and only starts heating up the nozzle when the bed is warm.
        • 27 replies
