fda food matetial
david-ganon
Posted · fda food matetial
thanks everyone :)
i ordered "xt-pla" and "t-glase" so i can do some tests.
also i discovered that if i print the "bendlay" in higher temp (250c-260c) i get MUCH !!! stronger and better results.
i used to print in 240c
so the bendlay act VERY good :)
    Hi. I use bendlay material for food aplications. But the layer bond is not good. I searching for something better and strong like pla or abs.
    food applications... im your friendly irish nosey parker.... :-) what kind of applications ? ;-)
    Ian
