Honey comb infill, skip every x layer infill, wipe, z scar control, only infill where needed...
Bump, surely someone on this forum has the answer?
Bump.
Did you find a solution ever since ? I'm having the same problem (missing options, Zscar and infill every n layer mostly, and disabling the extra infill Cura adds sometime), and can't yet find a way to make Slic3r work with the UM, and I don't want to test thousands of faulty gcode trying to extrude without heating or smashing the head into one axis's limit ....
It's a shame, because except for these few options, I'd choose Cura over Slic3r every time otherwise !
Daid 300
Which options do you miss?
