Daid, I would have thought the opposite and have the grub screws pulling the pulley to the round part of the shaft ensuring it is concentric. Plus it would be impossible to have the pulleys slip.
Could you explain a little more why not using the flat is better for print quality?
Daid 304
You can use those motors, if the wires are long enough. Just make sure you do NOT fasten the pulleys on the flat part. So the grub-screws in the pulleys should hold the axis on the round part, else you will get print quality problems.
