I think I remember reading somewhere the UM2 spring was replaced by a new version (weaker?) somewhere end Q1 this year. Probably not a big deal when you use roberts feeder as you have a lot of freedom for dailing in the correct tension... you could order at UM but you won't have it before you go to London I would just try a local hardwarestore if in a hurry ... took mine out to measure it, most is close exept for the height ...
- Outside diameter: 7.5mm
- Inside diameter: 4,7 mm
- String diameter: 1.3mm
- Height: 16 mm
Blizz 53
According to the UM2s BoM it's the same type as the UM1 (D2110, of which I can't find much). However spare pieces for the UM1 feeder everywhere have the same spec, can anyone confirm:
